Re: Re: Who Know the difference between a Super C
Posted by Randy in NE on July 22, 2003 at 04:17:40 from (216.58.237.20):
In Reply to: Re: Who Know the difference between a Super C and posted by Vern on July 21, 2003 at 21:30:57:
The C has a 113 cu. in. motor where the Super C has 123 cu. in. The C has band brakes where the Super C has disk brakes. They both have hydraulics. The Super C has a taller radiator which raises the gas tank a little and you will have about 3-4 inches of clearance between the hydraulic unit and the bottom of the gas tank. The Super C has a water pump. The brake peddles on the C are pretty straight where they are curved on the Super C. Some of these things came on the later C's towards the end of the production run. If your serial number is less than 100001 then it is a C. You can find this stamped on a flat spot right beneath #1 spark plug. Then click on the "Serial Numbers" link on the left side of this page.
Post A Followup
: Re: Re: Re: Who Know the difference between a Super C
