Re: Re: Re: Re: Generator/ alternator your thought
Posted by Ken K on July 22, 2003 at 08:34:45 from (67.200.32.54):
In Reply to: Re: Re: Re: Generator/ alternator your thoughts posted by Jim in Ontario on July 21, 2003 at 21:08:31:
Jim, I changed my H to 12 volt alternator but I had to use a alternator from a newer chevy because the Delco 10SI would not fit under the hood of the H. I used a alternator from a 87 chevy and fits ok. Only bad part is the newer, smaller alternators have a built in computer and voltage regulator which needs to have 3 to 6 volts to operate it. For this you have to use the resistor or lamp for this voltage. I also made a new pully as small as I could to get more rpm's. (This may not have to be done but I did it anyway.) Also, NEVER remove the battery wire from the battery while the tractor is running or you will ruin the computer (not voltage regulator, which it has built in also) in the alternator. I drilled a hole between the ammeter and light switch for the lamp (next to the fuse holder.) I bought a 12 volt battery for a Dodge mini van which fit quite well in the original battery box. (NEG. GROUND) Another thing I did is change the starter switch to a key switch and solenoid mounted behind the gas tank support, so I could remove the key so the grandchildren coulden't start the tractor. I just screwed the key switch into the hole where the old starter switch was. You must add the resistor to the coil and change the connections on the back of the ammeter also. Don't forget to change the light bulbs also. Now I just touch the starter and the H is running and even starting at low idel the alternator starts charging right away. I love it! Will e-mail pictures if you like. Ken
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
