Re: Re: Re: Farmall M Conversion from Tricycle to
Posted by Duhh on July 22, 2003 at 21:16:33 from (65.240.57.96):
In Reply to: Re: Re: Farmall M Conversion from Tricycle to Narr posted by Huh? on July 22, 2003 at 17:48:46:
The wheel bearings...The spindle diameter varies on these models. Even though the bolster may bolt up,,check the spindle size before you buy
Post A Followup
: Re: Re: Re: Re: Farmall M Conversion from Tricycle to
