Farmall Tractors Discussion Board
Re: Trailering a Farmall H
Posted by Don H. on September 22, 1999 at 14:28:37 from (152.163.195.213):
In Reply to: Trailering a Farmall H posted by Steve Sayers on September 22, 1999 at 13:34:35:
The factory weight for an H was 3725#, according to Guy Fay's book. How much heavier yours may be depends on whether it has fluid in the tires and any accessory equipment. It might weigh under 4000 lbs or it might be as much as 5500, so you need a trailer that will handle at least that much. I wouldn't tackle that without a trailer that has brakes, so the combination of weight and brakes probably means a tandem. You will need enough power to pull all that but most 1/2 ton pickups probably could get by, depending on the terrain you plan to pull it through. Good luck and drive carefully. There are some wild drivers out there that won't care as much about your precious cargo as you do.
Post a Followup
: Re: Re: Trailering a Farmall H
