Re: F-20 missing significantly when running light
Posted by here, try this on July 23, 2003 at 18:18:31 from (65.172.143.73):
In Reply to: F-20 missing significantly when running light posted by Pete L on July 23, 2003 at 09:08:44:
Does the rotor have a grove worn in it where the brushes ride? This will make the brushes jump and cause erratic spark. Take the rotor out and lay on a sheet of sandpaper on a flat surface and sand away. Don't worry they are quite thick and you can remove a lot of material.
Post A Followup
: Re: Re: F-20 missing significantly when running light
