Re: Re: H lift-all drive dog problem still ????
Posted by John on July 23, 2003 at 18:37:36 from (192.233.162.116):
In Reply to: Re: H lift-all drive dog problem still ???? posted by 49 Cubber! on July 22, 2003 at 19:02:15:
The shafts in the Lift-all and transmission are tight. The loose shaft is the one in the 2 sliding cuplers with the cotter pins (between the drive dogs). The drive dogs are on the threaded shaft ok. If I screw the drive dog in more on the transmission side, it is further away from the other side , then I can shake the shaft even more. If I take the shaft out, both drive dogs are tight on their shafts and would need a pipe wrench to get them off. The shaft in between is the one I can shake. Thanks.
Post A Followup
: Re: Re: Re: H lift-all drive dog problem still ????
