Re: Generator question rephrased!
Posted by steve on July 23, 2003 at 18:56:02 from (204.246.222.185):
In Reply to: Generator question rephrased! posted by BC on July 22, 2003 at 09:32:44:
take the A and F terminal wires off the generator. Ground the F terminal to the tractor frame. Start tractor and measure the voltage across the A and F terminals. with no regulator you will get about 12 volts on a 6 v gen and 20 volts on a 12 v system. This test does not include the voltage regulator.
Post A Followup
: Re: Re: Generator question rephrased!
