Re: M lift all hyd.pump
Posted by SteveSuperM on July 24, 2003 at 09:50:23 from (142.238.32.132):
In Reply to: M lift all hyd.pump posted by Rich Griffin on July 24, 2003 at 06:30:31:
My 53 super M does the same thing. I've been told about the check valves as well. The other advise I received from a knowlegeable man was that the cylinders could be leaking. They were used to store fluid on the low pressure side since there was not enough volume to run a loader in the reservoir alone. Would they both leak at the same rate.???
Post A Followup
: Re: Re: M lift all hyd.pump
