Re: Re: H Rebuild
Posted by SCCA SOLO on July 24, 2003 at 17:20:55 from (208.51.55.188):
In Reply to: Re: H Rebuild posted by LanceM on July 24, 2003 at 16:39:16:
Lance, Good question. I think it would depend on what the stock volumetric efficiency is. If it could be significantly increased you should see a hp increase. Say the stock VE is 65% (guess) and you were able to increase the VE to 75% through porting and assuming the intake and exhaust can keep up with the flow increase you potentially could see a gain of 0.52lbs/min of airflow (Calc. done using 152cid, 1650RPM, 80F, 29.92 in Hg atmospheric press, and 50% relative humidity.) Using the rule of thumb I found of for every 1lb of air yields 10 hp (assuming proper amount of fuel is added) thats a 5hp gain from a cheap mod. I don't know what fuel density that rule uses. The lower the fuel density the higher the energy density, sound right to anyone? I have no idea what the ports look like in the H, its entirely possible that a gain in VE of 10% through porting the head of an H is entirely unrealistic. VE varies with RPM, I believe thats why different cams are used for different applications; to shift the highest VE to the RPM you will be using most often. I basically wanted to know where the bottleneck is, maybe the head flows fine and attention needs to go to the carb or manifold, I don't know. I've seen on other posts that people have put a head from a 350 or something in an effort to increase flow. No Idea what RPM's they were targeting or Compression. I am new to tractor engines, but I know quite a bit about auto engines. Same rules should apply or at least I hope so. I am not trying to be smart either, just trying to learn the most I can.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
