Re: Gas Cap replacement from International
Posted by earlschieb on July 25, 2003 at 07:16:59 from (12.161.110.49):
In Reply to: Gas Cap replacement from International posted by Murray on July 25, 2003 at 06:19:20:
third party image
Here you go, you should be able to print this off and use it.
Post A Followup
: Re: Re: Gas Cap replacement from International
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
