Re: disc harrow on Farmall M?
Posted by Hugh MacKay on July 25, 2003 at 15:38:02 from (64.228.11.121):
In Reply to: disc harrow on Farmall M? posted by Simon on July 24, 2003 at 21:15:46:
Simon: I agree with Jimmy, get a good wheel controled trailer disk. It's not that disks are all that heavy, but rather that the weight is spread out wide and far behind your hitch point. The only way you can disk with mounted equipment is straight ahead, whereas the trailer will disk around turns. If you are seriously going to do good tillage be it disk or cultivator then you should never travel anywhere on field with implement raised.
Post A Followup
: Re: Re: disc harrow on Farmall M?
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
