Re: Hydraulic pump seal.
Posted by CNKS on July 25, 2003 at 20:08:19 from (207.178.96.212):
In Reply to: Hydraulic pump seal. posted by Brian on July 25, 2003 at 20:01:46:
You can find the generic O-ring anywhere. If you have a groove on the shaft, it might still leak. You can have the shaft rebuilt by a good (emphasize good) machine shop, or do as I did, and have the hole the shaft goes through drilled out and use a speedy sleeve. Speedy sleeve is too large for the original hole. Some pumps have a regular oil seal, if yours does, a speedy sleeve will work fine.
Post A Followup
: Re: Re: Hydraulic pump seal.
