Mark - A couple ways to determine ground polarity/voltage:
1 - Look at the voltage regulator. It MAY be marked for both voltage and polarity.
2 - With the jump box connected, turn on the lights or ignition and note which way the ammeter deflects. If it goes toward the left (discharge) your ground is correct. However if it deflects right (charge) the jump box is grounded backward.
Once the jump box is grounded correctly re-polarize the generator (jumper the BAT and ARM terminals at the regulator together for an instant.) Now start the engine and run at 1/2 throttle.
If the ammeter shows a charge you are all set. However if it still shows discharge either the system is 6 volt, and/or the generator/regulator have other issues.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
