Re: Farmall A Questions from a Newbie
Posted by Farmalldan on July 28, 2003 at 10:21:22 from (64.154.26.248):
In Reply to: Farmall A Questions from a Newbie posted by Bob B on July 27, 2003 at 19:17:14:
Bob, The cable kill switch is correct for early Farmall A & B tractors. Without parts book, I cannot tell you the change over serial number. If you don't want this mag and kill arrangement, I'll trade you a later mag and switch for it. The bracket beside your throttle is for the kill switch. It is not correct for your tractor, indicating a likely problem with the steering support shaft and replacement of same. The serial number plate was on the brake shaft cover on very early '39 models (later models on LH seat support). If it's gone, look for engine number on RH side of engine block just below number one plug. Originally chassis and engine numbers matched. If yours does not indicate '39 model, engine was likely changed. I don't believe oil petcocks are original with "L" shaped handles. I suspect these are aftermarket replacements. Other clues to '39 model are Dzuz hood fasteners (through mid '40 or so) instead of J hooks and missing reinforcement gussets on final drive housings where implements attach.
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
