Re: Air in fuel system
Posted by Hugh MacKay on July 29, 2003 at 03:48:32 from (216.208.58.132):
In Reply to: Air in fuel system posted by Bill in Florida on July 28, 2003 at 18:41:21:
Bill: I have to agree with others. While there is still fuel going through the pump, if pluged at tank, it will create enough vacume to suck air in where it would not normally come.
I had this happen with a combine once. The culprit turned out to be one of about 6 corn kernals floating around in tank. Every time it happened you could blow back to tank and unplug. Put t back together, bleed it and go again. At the end of season we removed the tank and found about 6 kernals of corn about twice their normal size and kind of like a soft rubber ball from being in diesel fuel.
Post A Followup
: Re: Re: Air in fuel system
