Re: Hard starting F-12 (AGAIN).
Posted by Karl Olmstead on July 29, 2003 at 14:15:40 from (198.76.182.111):
In Reply to: Hard starting F-12 (AGAIN). posted by Fred on July 28, 2003 at 15:50:34:
If you're talking about the high tension leadout, where the high voltage gets transferred from the coil to the distributor block, all you really need is a spring there; no brush is necessary since nothing is moving. Try spring out of a ball-point pen, or something similar.
The five connections down lower on the block do need brushes; they rub against the distributor rotor.
Post A Followup
: Re: Re: Hard starting F-12 (AGAIN).
