Re: Re: '50 farmall h, no cranking, new starter on
Posted by 49 Cubber! on July 29, 2003 at 19:30:45 from (207.144.231.51):
In Reply to: Re: '50 farmall h, no cranking, new starter on it posted by tony on July 29, 2003 at 19:02:25:
Battery to switch,then switch to starter,this is the push type switch which looks brassy right?What size cable you have on those two?You could have corroded up cables.Then you should have,in some sort of configuration a wire to your on/off switch,then to coil,from coil to distributor.IF the coil is a 6 volt coil,you need the resistor between the switch and the coil,not between the coil and distributor.
Post A Followup
: Re: Re: Re: '50 farmall h, no cranking, new starter on
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
