Re: Farmall 140 carburetor
Posted by rustyfarmall on July 30, 2003 at 11:05:49 from (199.120.81.235):
In Reply to: Farmall 140 carburetor posted by J. K. Hall on July 30, 2003 at 09:08:27:
Completely disassemble your carburetor, soak it overnight, rinse with HOT water, blow it dry, naking sure that all passages are open, reassemble, making sure float height is correct. Also make sure you are getting sufficient gas flow to the carb. And last, make sure that there are no vacuum leaks. If you do all this, you will not need a new carb.
Post A Followup
: Re: Re: Farmall 140 carburetor
