Re: Farmall M cyl. head.
Posted by randy hall on July 31, 2003 at 15:43:05 from (209.11.237.42):
In Reply to: Farmall M cyl. head. posted by DJA on July 30, 2003 at 15:34:37:
the rockerarms and pushrods are all the same. their are three different combustion chamber depths for m heads. the 8060 and the 8574 head are both gasoline heads.the tops of the valves are all same height. if you are using the right valves for the right head. if you use valves for a gasoline head in a lower compression head they will be too long.
Post A Followup
: Re: Re: Farmall M cyl. head.
