Re: H-Restoration/ Walnut Abbrasive.
Posted by terry on August 01, 2003 at 10:55:32 from (67.250.216.249):
In Reply to: H-Restoration/ Walnut Abbrasive. posted by Dave-42H on August 01, 2003 at 05:47:22:
You will probably get lots of advice, but here is mine!
I strip the tractor down to the bare frame, then I use a sand blaster after I have removed all the grease and oil accumulation. I do not sand blast down to the bare metal, I just use enough pressure to remove the loose flaking paint etc.
I do not prime, and if you are painting a Farmall, I buy paint that matches the final coat that is in a spray can. I use the spray cans to get into the hard to get places. After that paint has had time to dry based on the instructions on the spray can, I then put on the final coat using a paint gun.
good luck
Post A Followup
: Re: Re: H-Restoration/ Walnut Abbrasive.
