Re: 826 IH
Posted by ca on August 01, 2003 at 22:35:09 from (216.209.168.10):
In Reply to: 826 IH posted by JM on July 31, 2003 at 16:17:12:
Yes the 826 is a good unit. Doesn't like cold weather starting but a block heater will cure any winter starting trouble And get use to using the primer position on the pull cable under normal conditions when starting. We bought a used one 28 yrs ago. The tack only says it has 5000 hour on it for the last 15 years. But it most likely has twice that many hours on it now.
It does mostly litter work these days. We use 1066's for the heavy work. But if it does nead to pull something it can still do it like a 15ft no-till drill and cart in H-1's all day long. I don't know how that little 6 cylinder german does it but it still has guts after that many hours.
Post A Followup
: Re: Re: 826 IH
