Re: Re: using 3pt hitch conversion bars on 2pt fas
Posted by rad on August 02, 2003 at 10:13:54 from (12.248.222.142):
In Reply to: Re: using 3pt hitch conversion bars on 2pt fast hi posted by PUTTER on August 02, 2003 at 05:32:04:
Oh, thank you very much, I had no idea.
Is it correct then that 26 inch is CAT I and 32 is CAT II ?
I get the impression that the balls can somehow be used on both cat I and cat II, so I'm not sure about this either.
Thanks again.
Post A Followup
: Re: Re: Re: using 3pt hitch conversion bars on 2pt fas
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
