what happens when i cut the AC lines when taking t
Posted by Bryce Andreasen (Magnum) on August 02, 2003 at 20:04:03 from (209.74.224.182):
just like before, i am taking the cab off, and it has two hoses comeing out of each front corner, and one on each is for heater, and other is for the air conditioner. Now for the heater, i can just put a steel plug in the engine block, and it does not effect serculation? and the AC, i may be able to take the tin off, and unbolt the compressor, and take the lines and unit off without cutting the hoses. but if i do, is there anything harmfull about the freon? And now, about taking the cab off, can i just take the four main bolts off, the smaller ones holding the cab to the deck, hoses, wiring, and all, and lift the cab off without any trouble, or do the front and back filler peices have to come off later, or is it just easier that way? (it is the short style white cab)
Post A Followup
: Re: what happens when i cut the AC lines when taking t
