Re: M pto lever
Posted by here, try this on August 03, 2003 at 04:52:51 from (65.165.16.63):
In Reply to: M pto lever posted by 49 Cubber! on August 03, 2003 at 04:34:18:
I don't know why you couldn't make a new rod. might have to be 3/8 rod so it is not springy, route it up then bend to the right and come up on the right side of the seat. make it long enough so he don't have to reach over so far. The bend would be above the PTO sheild so it should work. Move the guide and drill it out for the larger rod. 3/8 rod can be bent cold. I use well rod or electric fence posts.
Post A Followup
: Re: Re: M pto lever
