Re: 6v, 12v negative or positive ground?
Posted by Bob M on March 30, 2009 at 11:29:50 from (151.190.254.108):
In Reply to: Re: 6v, 12v negative or positive ground? posted by Janicholson on March 30, 2009 at 10:48:34:
Jim - Good catch on the lights!
You can however still use the jump box but use only the ignition to check ammeter function.
And if it turns out the tractor IS 6 volt, don't run it longer than a few minutes from the jump box. Otherwise you may damage the points and coil.
