Re: Add extra hyd. valves to IH 806?
Posted by ACES on August 03, 2003 at 09:14:30 from (67.0.5.114):
In Reply to: Add extra hyd. valves to IH 806? posted by Jim A. on August 02, 2003 at 21:47:55:
You might at some scrap tractor sights. IH made a power beyond block that would bolt to the side of the valve stack under the seat and everything worked just as you asked. the first 06"s had a plate to end the stack then the end plate was part of the second valve. With power beyond block you can add as many valves as you wish.If a person drilled to holes in the right places you would great the same thing. Other wise Hugh is right hard to add valve with out loosing one on the tractor.
Post A Followup
: Re: Re: Add extra hyd. valves to IH 806?
