Re: Farmall M shooting raincap at me
Posted by Haas on August 03, 2003 at 14:17:04 from (12.65.60.75):
In Reply to: Farmall M shooting raincap at me posted by John Fox on August 03, 2003 at 08:03:42:
As the others said, something is wrong in the timing. If you have a magneto, it may be 180 degrees out of time. When that happens it will blow back through the intake system and blow the oil (and other things) out of the air cleaner. I you have battery igntion, check the wires to make sure they are correct when No. 1 cylinder is at TDC of the compression stroke.
Post A Followup
: Re: Re: Farmall M shooting raincap at me
