Re: Re: I-H 2-bottom plow
Posted by Hugh MacKay on August 03, 2003 at 19:45:25 from (64.228.11.34):
In Reply to: Re: I-H 2-bottom plow posted by FM on August 03, 2003 at 19:09:01:
FM: Not quite so fast, first we must determine type of tail wheel. If tail wheel has a linkage from the front wheel rockshsft to rear wheel activating the rear wheel to lift the back of plow then you have a little genius, but not necessarily a number 8. There were other two bottom little genius plows, although number 8 is most likely.
If there is a rigid tail wheel or no tail wheel than plow is a little wonder, number 1.
Little Wonder plows were built from 1927 to 1942, whilr Little Genius plows were built from 1928 to 1960.
Post A Followup
: Re: Re: Re: I-H 2-bottom plow
