Re: Farmall 140 Hydaulics
Posted by Gary-Miss on August 04, 2003 at 17:22:52 from (64.12.97.13):
In Reply to: Farmall 140 Hydaulics posted by Scott on August 04, 2003 at 16:40:50:
There is an O ring on each of the touch control rods. They are recessed inside the housing. You will need to make an extractor out of a welding rod or such. Putting them back in is no problem. Drain the touch control. You probably need to was the screen (held in by four bolts on the left side) anyway and this is a good time. Disconnect the hydraulic lines on the right side. You will need a NEW gasket for that. Disconnect thecontrol levers. remove the four mounting bolts. Unfasten the control valves from the left arms, remove the lift arms and pull the control valves out. Thjey aren't fastened to anything inside the unit. You will see the"O" rings up inside. You can buy a pair of universal rack and pinion boots to replace the boots from an auto parts store. When you get through, refill with oil, have a blow gun and a rag ready to shoot just a little air into the filler hole. You may not have to if you don't remove the lines from the pump itself. Good luck
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
