Re: Carb float has me frustrated and out of patien
Posted by terry on August 05, 2003 at 16:17:41 from (67.250.216.198):
In Reply to: Carb float has me frustrated and out of patience. posted by Dennis on August 05, 2003 at 14:30:58:
I can tell you what happened to me. I did what you did, but not 20 times, maybe 5. I found that the previous owner didn't crimp the keepers down to hold the float in place. Without the keepers in place, the pin falls down on one side and the float gets way out of adjustment.
If you buy a green one, you will have to go to a different forum!!
Post A Followup
: Re: Re: Carb float has me frustrated and out of patien
