Re: Re: Re: How do you get rust out of the carb
Posted by jal-SD on August 07, 2003 at 14:11:18 from (12.17.66.80):
In Reply to: Re: Re: How do you get rust out of the carb posted by rustyfarmall on August 07, 2003 at 08:13:38:
Yep, its a slow process. I used a plastic 5 gal bucket & suspended the part from copper wire wrapped around an old fiberglass arrow to keep it off the bottom of the bucket. I used a hose clamp to tie the wire to the part-gotta change the location from time to time, so it all gets a chance to clean. I also used a wire bursh from time to time to loosen the rust, changed the clamp's location then. I also just wrapped the wire around some things, but a clamp worked best-I think a good connection is really important. BTW, don't figure on using the hose clamp again. I connected the charger's clip to the wire. (Trust me, you DO NOT want the clip in the solution & don't ask how I know this.) I left the sacrificial tin sheet long enough so it was above the solution & connected directly to it. Make sure the part is completely submerged. I just used my battery charger on trickle charge & left it for several days. Water wasn't warm-did this last fall in garage when it was freezing outside. I cut up a coleman fuel can for the "sacrificial" metal thats needed. I'd used other "tin" cans, but the flat side of a coleman can worked the best-I just split the can down the narrow sides & cut across the top & bottom w/tin snips. (Careful, sharp edges can cut fingers-don't ask!) Biggest thing is that the part & the sacrificial tin chunk cannot touch, current must pass through the solution to work best. (You will be able to see movement in the solution. Rust actually moves from the part to the sacrificial tin chunk.) Don't remember which terminal goes where, gotta read Baggsy's article again to refresh my old brain. Getting a bad case of CRS disease, I guess. (Another $0.02 worth. jal-SD)
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
