Re: give input on radiator
Posted by Bob Kerr on August 08, 2003 at 08:11:49 from (64.12.97.13):
In Reply to: give input on radiator posted by bill on August 04, 2003 at 02:52:49:
That old radiator might be better than a new one! the new ones are way too thin and are prone to cracks. If the old one doesn't leak, just drain it and fill it with DISTILLED WATER and run it for a few hours, get the water good and hot. Drain it before it cools, and refill with distilled water and antifreeze mix. If you change it every year and use only distilled water or rain water for that matter, it will clean itself out! Well water over the years will build up scale both on the cylinder walls in the water jacket , the head, and the radiator.
Post A Followup
: Re: Re: give input on radiator
