Re: H mag point grease??
Posted by Theman on August 08, 2003 at 10:48:02 from (12.19.86.5):
In Reply to: H mag point grease?? posted by John on August 08, 2003 at 05:39:48:
If the 2:1 gear reduction piece that you removed to get to the points on your H4 magneto had a greasy dust film on the outside of it, I recommend you clean it and grease the gears in it too. If, by using the term "dielectric grease, you're referring to the grease that comes with an electronic ignition module, don't use it in a mag. You are looking for good lubrication properties, not insulation and heat transfer which is what dielectric grease is for. Also be careful around the points with grease. More isn't always better.
Post A Followup
: Re: Re: H mag point grease??
