Re: Hydraulic lift is weak on 756D Farmall
Posted by John on August 09, 2003 at 19:19:40 from (209.152.81.3):
In Reply to: Hydraulic lift is weak on 756D Farmall posted by HobbyFarmer on August 09, 2003 at 17:00:06:
It may not be the pump. Check the relief valve that is right below the seat on the right side. It is a square plug. I have put in a valve for a 1066 for higher pressure. I had a Westendorf loader on a 706 German diesel and had the same problem. After I put in the heavier valve, it worked good. I was told that it could ruin the pump, but that was 25 years ago, and it is still going.
Post A Followup
: Re: Re: Hydraulic lift is weak on 756D Farmall
