Re: Super A Timing Question
Posted by gene b on August 10, 2003 at 14:23:16 from (65.227.11.122):
In Reply to: Super A Timing Question posted by scotty on August 10, 2003 at 14:10:29:
Take the two screws off the rotor end of mag and rotate the gear so the rotor lines up with the # tower on the mag sounds like you only need to back up maybe two teeth on the mag check also your rotor as sometimes they get put on wrong but you are correct about the rotor lining up with #1 tower on the cap when all the other timing marks are correct. Also make sure you are on compression with #1cycl
Post A Followup
: Re: Re: Super A Timing Question
