Re: Re: hydrolic fluid in motor oil
Posted by CNKS on August 11, 2003 at 20:19:18 from (207.178.96.213):
In Reply to: Re: hydrolic fluid in motor oil posted by Ed on August 11, 2003 at 09:43:41:
The H and M used 30W non-detergent. The Cub, Super A and C used Touch Control fluid, the predecessor to Hy-Tran. I suppose 30W will work in the Touch Control, 10W is probably better, but will dilute the motor oil.
Post A Followup
: Re: Re: Re: hydrolic fluid in motor oil
