Re: Farmall 560 Diesel
Posted by RPM on August 12, 2003 at 06:48:02 from (209.152.115.185):
In Reply to: Farmall 560 Diesel posted by bryan ross on August 11, 2003 at 19:01:36:
560 series was a good tractor in its day, built 58-63, it has aged 40 years now though, if you plan on using it hard check out the rear axle bearings, the head gasket on diesels was a problem, particularly if its turbocharged, make sure about sleeve protrusion and top of deck straight, check head for warp, remove 2 threads from the tapped holes for head bolts (never seen studs in this engine), this keeps the deck from distorting around each hole, replace with high quality grade 8 cap screws, Case-IH or better.
Post A Followup
: Re: Re: Farmall 560 Diesel
