Farmall Tractors Discussion Board
Charging/Light Switch on 48 Super A
Posted by Marvin on September 23, 1999 at 10:24:53 from (134.134.248.18):
I have beening reading some back posts on generators and how they work. I dug into my generator and wiring last night and started to trace the wires out using a ohmmeter. The charging/light switch has four wires attaching to it. One from the fuse, one from the field terminal of the genreator, one from the headlights and one wire that comes out of the box that is cut off and goes no where. I am un able to determine what is it should be connected to.
I know I need to buy a manual and I will as soon as another pay day or two rolls around. DOes anyone have a manual that they could tell what this other wire goes to?
Post a Followup
: Re: Charging/Light Switch on 48 Super A
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
