Re: Hydrolic spool valve question
Posted by Dan on August 14, 2003 at 06:50:26 from (12.18.162.69):
In Reply to: Hydrolic spool valve question posted by Tom W on August 14, 2003 at 06:30:59:
The float setting is usually used with a loader. you put the bucket down and in float setting it has neither down pressure or up pressure, will allow it to sort of float along the ground. Usually achieved by one of the positions of the valve handle. I use teflon tape on most fittings. I bought a hydraulic cylinder once that said not to use the tape so I used the teflon liquid. seems to work about the same but easier to use.
Post A Followup
: Re: Re: Hydrolic spool valve question
