Re: Farmall H Newbie questions
Posted by Paul in Mich on August 15, 2003 at 19:36:24 from (66.188.4.217):
In Reply to: Farmall H Newbie questions posted by Justin M on August 15, 2003 at 18:35:04:
If you have constant dripping from the bottom of your carb, then odds are that the float isn't set low enough, therefore the needle valve isn't shutting off the fuel before it overflows and runs out. I had the same problem with my H. you can tweak the float without taking the entire carb off the tractor. You can remove the bottom portion by removing the choke lever, the air cleaner hose, and 3 screws that hold the bottom of the carb to the top. There are some specks in the manual, but if your float isnt formed just right, the specks won't matter. You just have to adjust little by little until the flooding stops. Just make sure that the float has free movement, and doesn't hang up. Good luck. I got mine right on the 3rd try.
Post A Followup
: Re: Re: Farmall H Newbie questions
