Re: farmall 504
Posted by Diesel Don on August 15, 2003 at 20:54:39 from (206.40.119.90):
In Reply to: farmall 504 posted by HAWK on August 15, 2003 at 01:21:11:
Hi folks. Haven't been here in a while so I thought I'd check in, and happened to hit a good post. Here's one for you. A friend of mine called me up today and asked me to look at his 504. At the time, he had it hooked to a Gehl 1090 haybine and I think it may have caused his trouble. He had told me he was running the haybine and all of a sudden it developed a bad miss. He had done all the normal checks and repairs-carb,plugs,points,condenser,wires(although he installed resistor wires and I told him to ditch them),and even a second set of plugs.Nothing would work. I pulled the plugs and looked at them myself. #3 and #4 were somewhat blackened but not oil fouled. #'s 3&4 were missing. I did a compression test 1-150, 2-150, 3-150, 4-0psi. I think he overworked it and burned up the valves in #4. The point of my post is the 504 is a good tractor if it is used as it was intended. I don't think pulling what appeared to be a 10' haybine is what it was made for.
Post A Followup
: Re: Re: farmall 504
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
