Re: Push / Pull On/off Switch for Super A
Posted by justin on August 18, 2003 at 20:45:57 from (12.34.184.102):
In Reply to: Push / Pull On/off Switch for Super A posted by brian on August 18, 2003 at 18:46:54:
Now does it not fit due to the diameter of the hole, or does it not tighten down on the insturment panel" The single and double pole switches are the same diameter, I just assume that you don't have the extra thick washer that takes up the slack so the switch fits tight to the insturment box..
Post A Followup
: Re: Re: Push / Pull On/off Switch for Super A
