With low compression you probably have poor manifold vacuum. Hold your hand over the throat of the carburetor while someone makes an attempt to start the tractor. If there's poor suction on your hand you may have a leak around the intake manifold or at the base of the carburetor.
The engine may be due for a rebuild. When you get it running take it out and work it hard like plowing or disking. Then see if there's any improvement in starting. Hal
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
