C123 Pistons
Posted by Question for Hugh Mackay on August 19, 2003 at 20:49:04 from (66.248.101.99):
Hugh, I just pulled the head off my Farmall 100 to just check the top of the pistons and sleeve wear. I noticed that the pistons only come up to about 1/4 inch from the top of the block. Have you heard of a vendor that might handle flat top pistons that have the wrist pin located a little lower in the piston to gain a little more compression? IH did not build a propane version with a higher compression head. I would like to get the compression up to around 8 to 1.
Post A Followup
: Re: C123 Pistons
