Farmall Tractors Discussion Board
Follow-up..cylinder head stud spins
Posted by Bill(Tx) on September 23, 1999 at 15:27:56 from (192.105.235.146):
Of the two choices to either heli-coil or tap new threads for the H, I'm getting the machine shop to make a new stud, bottom threads fit an M, and the top threads match the standard H studs. I believe the block can better take the stress of the slightly larger stud than the cylinder head. I'm also going with the suggestion to install an new head gasket. All of this was needed to prevent coolant from entering the crankcase via the right front of the block after an otherwise sucessful overhaul. Thanks for the help.
Post a Followup
: Re: Follow-up..cylinder head stud spins
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
