Re: Farmall 340
Posted by Oldfarmboy Jim on August 20, 2003 at 21:00:47 from (12.80.105.119):
In Reply to: Farmall 340 posted by Wes on August 20, 2003 at 09:44:17:
I've been working on bringing a TD340 crawler back to life after it sat for somewhere between 5 and 8 years (owner can't remember for sure). Anyway, after tinkering for a few weeks and not getting fuel up at the injectors, I bought a service manual for the ROOSA MASTER injector pump and took it apart, found the problem, put new seals and gaskets in and now it runs fine. These are old tractors and parts can be a bear. ROOSA MASTER is now STANADYNE Corp. and there is no IH any more Komatsu handles some IH parts. But if you like IH and enjoy tinkering, then a 340 could be a blast. Hope this helps. Jim
Post A Followup
: Re: Re: Farmall 340
