Re: 57 farmall 230
Posted by RLS ia on August 21, 2003 at 16:44:06 from (207.192.229.170):
In Reply to: 57 farmall 230 posted by DENNIS in NC on August 21, 2003 at 14:58:11:
Dennis,
The pilot bearing in the flywheel might be froze up causing the transmission shaft to turn all the time. You might have to have someone pull start you and disengage the clutch and hit the brakes to try to get it freed up. Or the clutch might be stuck to the flywheel.
Good luck, hope this helps
Post A Followup
: Re: Re: 57 farmall 230
