Re: I CAN'T GET MYH TO RUN, HELP PLEASE!!!!!!!!!!!
Posted by PGNS on August 22, 2003 at 06:23:41 from (142.176.86.254):
In Reply to: I CAN'T GET MYH TO RUN, HELP PLEASE!!!!!!!!!!!!!!! posted by FARMIN RED on August 22, 2003 at 05:59:46:
You must have dislodged some dirt or rust in the gas tank and plugged up the carb. Remove the carb and clean, get a new seat and needle, remove gas line and check for any obstructions, check filter system- clean or replace, check gas tank again for any sign of rust or dirt.Once you do all this open up the gass line to check the flow from the tank, if it is good, connect back to carb and strat it up. If the flow is slow you have dirt or rust stuck in the sediment bowl assy- clean out or replace. Good luck! Take you time.
Post A Followup
: Re: Re: I CAN'T GET MYH TO RUN, HELP PLEASE!!!!!!!!!!!
