Re: Farmall B - Fuel Filter
Posted by Andy Martin on August 25, 2003 at 16:13:50 from (12.86.234.82):
In Reply to: Farmall B - Fuel Filter posted by Big Tex on August 25, 2003 at 14:53:45:
Assuming you mean the sediment bowl, only when you see a buildup of sediment in the bottom of the bowl. If you see a line across the bowl, this may be the interface between water in the bottom and gas at the top. This also indicates a need to clean. My experienced hay hand finished raking a field with the choke mostly pulled out to get the tractor to run. He had removed the carburetor bowl twice to try to clean it out. The sediment bowl was completely full of water. Tractor ran fine after I dumped it. He was a little embarrassed. To clean the sediment bowl, use a little carburetor cleaner to clean the threads, if necessary. Shut off the fuel (L shaped lever at top of housing), unscrew nut under bowl, remove and clean. If it has not been off in a while be ready to replace the gasket. If it is a glass bowl try not to drop it (very easy to do). Reinstall and turn the gas on. If the carburetor is full of gas the bowl may not fill up. Don't worry, it will after you start it. Rinse the spilled gas off with water before you start the tractor. In the field you can use a cup full from your water jug. It rinses off pretty easily. Just a little will not cause a problem, but gas spilled on the starter-mounted switch can be a big problem if not rinsed off. If you can let it set for a couple of hours all the flammable components will be gone even though the smell is still there. I burned one C by not rinsing it off. Almost had the fire out when the fuel bowl broke and caught the rear tires.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
