Re: M axle bearing HELP!!!
Posted by CNKS on August 25, 2003 at 19:21:01 from (207.178.96.214):
In Reply to: M axle bearing HELP!!! posted by Joe on August 25, 2003 at 19:06:07:
I have replaced these bearings in a C and an H, but as part of restorations, when I had the transmission cover off. Others will probably tell you to remove the pto, slide the bull gear off, and either slide the axle out or remove the axle housing and axle. It seems to me if the outer bearing is shot, perhaps the inner one should be replaced too. I can be corrected, but if my memory serves me right, I know of no bearing puller that will work, just not enough room.
Post A Followup
: Re: Re: M axle bearing HELP!!!
